[mapguide-users] Context menus -> selection (query results in task bar)
greg_sk Gregor.Skrt at elektro-primorska.si
Tue Oct 22 23:18:28 PDT 2013
I tried to run *php* script from "ContextMenu". For example I'd like to run
*"property_report.php"* from context menu for some feature and do other sql
stuff later on parameters. Problem is that I have to pass at least:
$sessionId = $args['SESSION'];
$xmlSelection = $args['SELECTION'];
$mapName = $args['MAPNAME'];
What I can figure out from code:  there is a submit function that passes
parameters to property_report.php. What I can't figure out is how to pass
selection and session parameters from context menu to php script.
Any help on this point would be very appriciated.
Thanks in advance.
Gregor
View this message in context: http://osgeo-org.1560.x6.nabble.com/Context-menus-selection-query-results-in-task-bar-tp5085236.html
