[mapguide-users] Remove Overview Map from Map Widget
GordonL gordon.luckett at arrowgeomatics.com
Fri Oct 25 15:45:17 PDT 2013
Unfortunately if you remove the map from the Fusion Application Definition,
you can't use it in the overview map so it will always have to be in your
Map Dropdown widget.
I haven't done it yet, but I am thinking of using the OpenLayers widget
rather than the one with mapguide for the overview map.
http://dev.openlayers.org/releases/OpenLayers-2.13.1/examples/overviewmap.html
View this message in context: http://osgeo-org.1560.x6.nabble.com/Remove-Overview-Map-from-Map-Widget-tp5062685p5085859.html
