[mapguide-users] Label problem at detailed scale
Anna Sevegnani anna.sevegnani at gmail.com
Mon Sep 2 07:56:11 PDT 2013
I did several tests but unfortunately changing the parameter does not solve
the label problem.
On Tue, Aug 27, 2013 at 4:01 PM, Anna Sevegnani <anna.sevegnani at gmail.com>wrote:
> Yes is a single label id "FERROVIA BASSANO-PADOVA" and span more than 2
> tiles.
> Any idea?
> On Tue, Aug 27, 2013 at 9:34 AM, Anna Sevegnani <anna.sevegnani at gmail.com>wrote:
>> I have implemented what Jackie suggested for printing large maps,
>> but it remains the problem of cropped labels at lower scale:
>> http://osgeo-org.1560.x6.nabble.com/Re-Dinamic-Tile-Render-tp5046148p5046278.html
>> Create a big tile and crop is really slow.
>> On Mon, Aug 26, 2013 at 5:42 PM, Anna Sevegnani <anna.sevegnani at gmail.com
>> > wrote:
>>> There is a way to prevent label cropping on boundaries at lower scale?
>>> On Thu, Aug 22, 2013 at 11:26 PM, Anna Sevegnani <
>>> anna.sevegnani at gmail.com> wrote:
>>>> Yes the problem are the cropped labels on boundaries.
>>>> Il giorno 22/ago/2013 16:57, "Anna Sevegnani" <anna.sevegnani at gmail.com>
>>>> ha scritto:
>>>>  I've a problem with label on base Layer Groups at high detailed scale
>>>>> lower than 1128,49722.
>>>>> Label size id defined in Map space.
>>>>> http://93.89.61.138/users/xx/image.png
>>>>> MapGuide Maestro 5.0.0.7698
>>>>> MapGuide Opensource 2.5.1.7768
>>>>> Windows Server 2008 64bit
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130902/0c27f626/attachment.html>
