[mapguide-users] Basemap printing with Quickplot (fusion) MGOS 2.5
Bernhard Maehler
bernhard.maehler at gmx.de
Mon Sep 2 12:06:39 PDT 2013
I have the same problem with AIMS 2014 and it seems to a bug in Fusion.
By default Fusion QuickPlot prints always the first base layer of a map even
though the layer has been switched off.
Also Fusion MapSave widget saves always the first base layer.
Example:
http://www.geoportal.hilden.de/karten/stadtkarte/
This simple map contains two base layer:
A city map (layer Stadtplan) which is the first base layer and an aerial map
(layer Luftbildkarte), the second base layer.
Steps to reproduce :
1. Switch on the layer "Luftbildkarte" and Switch off the layer "Stadtplan"
2. Call QuickPlot (Karte drucken -> PDF Druck)
3. Print the map (Button "Drucken" in Task Pane)
or
4. Call SaveMap (Karte speichern -> PNG-Format)
I have posted this issue to Autodesk Subscription Center.
Bernhard
View this message in context: http://osgeo-org.1560.x6.nabble.com/Basemap-printing-with-Quickplot-fusion-MGOS-2-5-tp5075538p5075675.html
