[mapguide-users] Basemap printing with Quickplot (fusion) MGOS 2.5
Jackie Ng jumpinjackie at gmail.com
Mon Sep 2 19:55:15 PDT 2013
I think I know what's happening.
When Fusion makes OpenLayers.Layer.MapGuide instances for each tiled layer
group, it doesn't seem to be attaching the runtime map name to these
instances. Thus when these groups are toggled on/off in the Legend, there's
no map name to identify the server-side MgMap instance where we need to
toggle these base layer groups on and off.
When you do a QuickPlot, it's doing a RenderMap of the MgMap instance which
is not aware that the base layer group has been turned off, so that's
probably why those layers are still drawn in a Quick Plot or any Rendering
Service API.
Make a ticket under the Fusion trac instance about this if you can.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Basemap-printing-with-Quickplot-fusion-MGOS-2-5-tp5075538p5075709.html
