[mapguide-users] Coordinate system initialization failed
Mike Micallef
Michael.Micallef at ontario.ca
Thu Sep 12 08:10:36 PDT 2013
Hi - thanks for any insight
I am having the same/similar problem here -
Windows 7 - 64 bit - clean install - no previous versions of MGOS
installed "MapGuideOpenSource-2.5.1.7768-Final-x64.exe" package
2 days ago
Tried to run working maps migrated from MGOS 2.2 getting an error on both
raster and vector layers not in the same coordinate system of the map from
what I gather...
All other layers work fine.
Server Error Log: excerpt
/<2013-09-12T10:25:04> 10552
Success: Server started.
<2013-09-12T10:25:10> 8680 Ajax Viewer 142.142.41.193 Administrator
Error: Failed to stylize layer: MTO Routes
The coordinate system initialization failed.
Could not initialize the geodetic transformation.
StackTrace:
- MgMappingUtil.StylizeLayers() line 892 file
c:\working\build_area\mapguide\2.5.1\x64\mgdev\server\src\services\mapping\MappingUtil.cpp
<2013-09-12T10:25:10> 11120 Ajax Viewer 142.142.41.193 Administrator
Error: The coordinate system initialization failed.
StackTrace:
- MgRenderingServiceHandler.ProcessOperation() line 83 file
c:\working\build_area\mapguide\2.5.1\x64\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
- MgOpQueryFeatures.Execute() line 125 file
c:\working\build_area\mapguide\2.5.1\x64\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
- MgServerRenderingService.QueryFeatures() line 853 file
c:\working\build_area\mapguide\2.5.1\x64\mgdev\server\src\services\rendering\ServerRenderingService.cpp
- MgServerRenderingService.RenderForSelection() line 1525 file
- MgCoordinateSystemFactory.GetTransform() line 221 file
c:\working\build_area\mapguide\2.5.1\x64\mgdev\common\geometry\CoordinateSystem/CoordinateSystemFactory.cpp
- MgCoordinateSystemTransform.SetSourceAndTarget() line 849 file
..\CoordinateSystem\CoordSysTransform.cpp
<2013-09-12T10:25:11> 4040 Ajax Viewer 142.142.41.193 Administrator
StackTrace:
<2013-09-12T10:25:12> 8700 Ajax Viewer 142.142.41.193 Administrator
Could not initialize the geodetic transformation./
KiM wrote
> I have 2 different servers, one mapguide server and one application
> server.
> I installed MapGuide 2.5.
> When I'm trying to connect with Maestro or try to connect with MapGuide in
> my application, I always get the following error: The coordinate system
> I tried almost everything: reinstall, upgrade to 2.5.1,... but the
> endresult stays the same...
> server.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Coordinate-system-initialization-failed-tp5077294p5077538.html
