[mapguide-users] Coordinate system initialization failed
Zac Spitzer zac.spitzer at gmail.com
Wed Sep 18 19:11:20 PDT 2013
if you open the feature source in Maestro, does it detect the correct CS?
On Fri, Sep 13, 2013 at 1:10 AM, Mike Micallef
<Michael.Micallef at ontario.ca>wrote:
> Hi - thanks for any insight
> I am having the same/similar problem here -
> Windows 7 - 64 bit - clean install - no previous versions of MGOS
> installed "MapGuideOpenSource-2.5.1.7768-Final-x64.exe" package
> 2 days ago
> Tried to run working maps migrated from MGOS 2.2 getting an error on both
> raster and vector layers not in the same coordinate system of the map from
> what I gather...
> All other layers work fine.
> Server Error Log: excerpt
> /<2013-09-12T10:25:04>  10552
>  Success: Server started.
> <2013-09-12T10:25:10>   8680    Ajax Viewer     142.142.41.193
>  Administrator
>  Error: Failed to stylize layer: MTO Routes
>         The coordinate system initialization failed.
>         Could not initialize the geodetic transformation.
>  StackTrace:
>   - MgMappingUtil.StylizeLayers() line 892 file
> c:\working\build_area\mapguide\2.5.1\x64\mgdev\server\src\services\mapping\MappingUtil.cpp
> <2013-09-12T10:25:10>   11120   Ajax Viewer     142.142.41.193
>  Administrator
>  Error: The coordinate system initialization failed.
>  StackTrace:
>   - MgRenderingServiceHandler.ProcessOperation() line 83 file
> c:\working\build_area\mapguide\2.5.1\x64\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
>   - MgOpQueryFeatures.Execute() line 125 file
> c:\working\build_area\mapguide\2.5.1\x64\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
>   - MgServerRenderingService.QueryFeatures() line 853 file
> c:\working\build_area\mapguide\2.5.1\x64\mgdev\server\src\services\rendering\ServerRenderingService.cpp
>   - MgServerRenderingService.RenderForSelection() line 1525 file
>   - MgCoordinateSystemFactory.GetTransform() line 221 file
> c:\working\build_area\mapguide\2.5.1\x64\mgdev\common\geometry\CoordinateSystem/CoordinateSystemFactory.cpp
>   - MgCoordinateSystemTransform.SetSourceAndTarget() line 849 file
> ..\CoordinateSystem\CoordSysTransform.cpp
> <2013-09-12T10:25:11>   4040    Ajax Viewer     142.142.41.193
>  Administrator
>  StackTrace:
> <2013-09-12T10:25:12>   8700    Ajax Viewer     142.142.41.193
>  Administrator
>         Could not initialize the geodetic transformation./
> KiM wrote
> > I have 2 different servers, one mapguide server and one application
> > server.
> > I installed MapGuide 2.5.
> > When I'm trying to connect with Maestro or try to connect with MapGuide
> in
> > my application, I always get the following error: The coordinate system
> > I tried almost everything: reinstall, upgrade to 2.5.1,... but the
> > endresult stays the same...
> > server.
> in
> http://osgeo-org.1560.x6.nabble.com/Coordinate-system-initialization-failed-tp5077294p5077538.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130919/a1ed5d0e/attachment.html>
