[mapguide-users] Step by Step Mrsid Gdal support implementation for packaged MGOS 2.5.1
Mike Micallef Michael.Micallef at ontario.ca
Thu Sep 12 12:34:31 PDT 2013
Can someone post a step by step for enabling mrsid images from the "2.5.1
packaged install" to "up and running with mrsid support" on windows 7 64 bit
(non iis) .I have been trying with much failure to ensure I have all the
gdal and other required dlls - different dlls from previous versions from
some of the other posts.Is this the correct GDAL Package to use for Mrsid
support?
http://www.gisinternals.com/sdk/PackageList.aspx?file=release-1600-x64-gdal-1-9-0-mapserver-6-0-1.zip
<http://www.gisinternals.com/sdk/PackageList.aspx?file=release-1600-x64-gdal-1-9-0-mapserver-6-0-1.zip>
if so - it does not contain this reference as well as others from previous
versions (mgos 2.2)...lti_dsdk_cdll.dllThere are several other examples but
none that coinside with what is listed.Ideally I am looking for: *-the
required URL's to the files needed -a list of which files from where and
where they should be placed-an overview of the process required*I run into
this with every upgrade and spend days moving platforms trying to get mrsid
up and running.Any help is much appreciated.systemWin 7 - 64 bitMapguide
2.51 - Apache bundle - MapGuideOpenSource-2.5.1.7768-Final-x64.exethis may
be linked to other issues I am having with transforming raster layers.Mike
View this message in context: http://osgeo-org.1560.x6.nabble.com/Step-by-Step-Mrsid-Gdal-support-implementation-for-packaged-MGOS-2-5-1-tp5077599.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130912/97d1fd0a/attachment.html>
