[mapguide-users] FeatureService.QueryFeatureSource does not work if column name is none ASCII
Jackie Ng
jumpinjackie at gmail.com
Mon Sep 16 06:08:14 PDT 2013
Gut feeling is MapGuide or FDO as Maestro API simply passes down the relevant
parameters to the SelectFeatures API.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/FeatureService-QueryFeatureSource-does-not-work-if-column-name-is-none-ASCII-tp5078051p5078069.html
