[mapguide-users] FeatureService.QueryFeatureSource does not work if column name is none ASCII
Hans Milling
hm at geograf.dk
Mon Sep 16 06:32:59 PDT 2013
I tried to enable the FDO sql logging, and it seems that the request to the
SQL server is identical. Must be FDO/MapGuide then. Can MapGuide dump what
is returned by the FDO provider? To check if it's the provider that returns
nothing or if it's MapGuide that cannot handle none ASCII column names?
Hans...
View this message in context: http://osgeo-org.1560.x6.nabble.com/FeatureService-QueryFeatureSource-does-not-work-if-column-name-is-none-ASCII-tp5078051p5078074.html
