[mapguide-users] FeatureService.QueryFeatureSource does not work if column name is none ASCII
Zac Spitzer
zac.spitzer at gmail.com
Wed Sep 18 18:59:41 PDT 2013
Can you try this out with the latest release? 2.2 is rather ancient, this
might of already been addressed
On Mon, Sep 16, 2013 at 11:32 PM, Hans Milling <hm at geograf.dk> wrote:
> I tried to enable the FDO sql logging, and it seems that the request to the
> SQL server is identical. Must be FDO/MapGuide then. Can MapGuide dump what
> is returned by the FDO provider? To check if it's the provider that returns
> nothing or if it's MapGuide that cannot handle none ASCII column names?
> Hans...
> http://osgeo-org.1560.x6.nabble.com/FeatureService-QueryFeatureSource-does-not-work-if-column-name-is-none-ASCII-tp5078051p5078074.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130919/d75b51be/attachment.html>
