[mapguide-users] AIMS 2013 Oracle spatial does not work
weslleywang
weslleywang at gmail.com
Wed Sep 18 11:07:56 PDT 2013
Hi Gabor:
not working.
Update:
the error doesn’t happen in the MgViewerExtention project, it happens in
the file C:\Program Files\Autodesk\Autodesk Infrastructure Web Server
Extension 2013\www\mapviewernet\mapframe.aspx. Line105:
map.Create(resourceSrvc, resId, mapName);
When I check the exception .Message and exception.StackTrace, It information
is below:
The map definition is invalid.- MgMap.Create() line 328 file
d:\build\ims2013\build_52.8\ent\os\common\mapguidecommon\MapLayer/Map.cpp.
For Sheboycan there is no problem, but for our Map, it happens.
Is there any bug in AIMS 2013? should I use 2014?
Anybody have a example dynamically filtering the oracle spatial layer, or
know where I can find one, I really appreciate.
Thanks
Wes
View this message in context: http://osgeo-org.1560.x6.nabble.com/AIMS-2013-Oracle-spatial-does-not-work-tp5078335p5078525.html
