[mapguide-users] Limiting number of results from Maestro QueryFeatureSource or mapagent SELECTFEATURES?
Jackie Ng
jumpinjackie at gmail.com
Tue Apr 22 18:30:47 PDT 2014
There is no server-side limiting mechanism at the moment. The limiting
mechanism is purely on the MaestroAPI side.
Having said that, if you're using MGOS 2.5 or newer, feature query responses
are now chunked meaning content will be written out to the wire as the
server-side feature reader is being iterated upon. There is very little
internal buffering of the reader content on the server-side. We only buffer
enough content in order to transmit a valid chunk of XML or JSON
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Limiting-number-of-results-from-Maestro-QueryFeatureSource-or-mapagent-SELECTFEATURES-tp5135715p5136595.html
