[mapguide-users] Data sources location list
GordonL
gordon.luckett at arrowgeomatics.com
Tue Dec 23 13:02:59 PST 2014
What I would do is create Packages from each sub-folder.
Rename the MGP to ZIP and unzip.
Search the XML files for "%MG_DATA_FILE_PATH%" like Jackie mentioned
above.
Those will direct you to the files that are directly loaded with a load
procedure rather than the unmanaged files.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Data-sources-location-list-tp5178730p5179052.html
