[mapguide-users] R: Mapguide vs OpenLayers: troubles with tiles on EPSG 21781
Francesco Sozzi
fsozzi at intercad.ch
Sun Feb 2 03:43:59 PST 2014
The error has been the wrong base layer name
Regards
Franz
-----Messaggio originale-----
Da: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] Per conto di Franz1965
Inviato: domenica, 2. febbraio 2014 01:44
A: mapguide-users at lists.osgeo.org
Oggetto: [mapguide-users] Mapguide vs OpenLayers: troubles with tiles on
EPSG 21781
Hi everybody,
I have no problem with OpenLayers sample on Mapguide if I execute on
Sheboygan, bot tiled and not tiled.
I have no problems if I convert this sample on my project on EPSG:21781 on
not-tiled version.
But tiled map does not display. I can display tiled map on AjaxViewer or
Maestro, but not on OpenLayers.
Any idea?...
Best regards
//tiled version
function initTiled(){
var extent = new
OpenLayers.Bounds(562985.576,158127.222,568066.399,165643.041);
var tempScales = [35000,15000,5000,1500,500,200,100];
var mapOptions = {
maxExtent: extent,
scales: tempScales
map = new OpenLayers.Map( 'map', mapOptions );
var params = {
mapdefinition:
'Library://INFOGEO/MyProject/Default.MapDefinition',
basemaplayergroupname: "Base Layer Group"
var options = {
singleTile: false
var layer = new OpenLayers.Layer.MapGuide( "MapGuide OS tiled
layer", url, params, options );
map.addLayer(layer);
map.zoomToMaxExtent();
//un-tiled version
function initUntiled() {
var extent = new
var mapOptions = {
units: 'm',
projection: 'EPSG:21781',
maxExtent: extent,
maxResolution: 'auto',
controls: []
map = new OpenLayers.Map( 'map2', mapOptions );
map.addControl(new OpenLayers.Control.NavToolbar());
map.addControl(new OpenLayers.Control.PanZoom());
map.addControl(new OpenLayers.Control.NavigationHistory());
var options = {
isBaseLayer: true,
transitionEffect: "resize",
buffer: 1,
useOverlay: false,
useAsyncOverlay: false,
singleTile: true
var params = {
mapdefinition: 'Library://INFOGEO/MyProject/Default.MapDefinition'
var layer = new OpenLayers.Layer.MapGuide( "MapGuide OS untiled
baselayer", url, params, options );
map.addControl(new OpenLayers.Control.LayerSwitcher());
View this message in context:
http://osgeo-org.1560.x6.nabble.com/Mapguide-vs-OpenLayers-troubles-with-til
es-on-EPSG-21781-tp5101387.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
