[mapguide-users] Tiled basemap group from raster doesn't show
Berg, James
James.Berg at stantec.com
Thu Feb 20 07:16:19 PST 2014
I implemented a workaround for this problem. Still not sure of the actual cause, though.
In the ShowBaseGroup() function in ajaxmappane.templ add Refresh(); to the end of the function. This forces the map to refresh whenever base map group is activated. This will make redundant refreshes for base map groups that appear on map load and work properly, but the effects aren't noticeable to me.
