[mapguide-users] Tooltip responsiveness (Fusion)
Jackie Ng jumpinjackie at gmail.com
Mon Jan 6 22:01:03 PST 2014
If you look at the requests tab of your browser developer tools, do you see a
clear time gap in the QUERYMAPFEATURES requests? These are the requests for
tooltip data.
You mention that your feature join is between 3 data sources? Are the table
and view from the same MySQL database? If so, you should probably try to do
such joins at the database level.
What is the size of the MySQL table/view? If you're joining SDF data to
attributes in a MySQL table/view, then MapGuide has to "SELECT *" query the
table/view before it can start finding the matching records based on the
join values of the SDF side.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Tooltip-responsiveness-Fusion-tp5096654p5096674.html
