[mapguide-users] Connecting to Feature Source
MitchGreig
mitchell.greig at altusgroup.com
Tue Jan 7 07:25:20 PST 2014
We successfully use postgis 2.1. Your error is saying it cannot find the
necessary relation "geometry_columns". If you run the command "SELECT * FROM
geometry_columns;" in the DB you are using, you should get a result table
showing every spatial table's geometry columns. If you do not get this, then
there is a problem with your postgis installation. I would suggest then
reisnstalling postgis's template database, making a database based on it and
testing from there. If that works, look at what is different with your main
DB.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Connecting-to-Feature-Source-tp5095965p5096800.html
