[mapguide-users] Feature Reader Not picking up selection
Mark Spence
Mark.Spence at aitspatial.co.uk
Tue Jan 21 03:50:56 PST 2014
Hi All,
I am stumped with the following scenario.
A view from SQL Server 2008 R2 which is published using schema overrides as per Jackie's article. Everything published and themes fine, selectable etc etc
However, when I try to get the object key to pass via through to my .net listing report the
MgFeatureReader featureReader = featureService.SelectFeatures(layerFeatureResource, layerclassname, queryOptions);
while (featureReader.ReadNext())
Simply hits the bottom of the loop - indicating the featurereader is empty.
The only difference to the hundreds of these I have done before is that the object key data type is int rather than string.
Anyone experience similar?
Mark S
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140121/143b0260/attachment.html>
