[mapguide-users] RenderMap and selection color wish
amorsell
andy.morsell at autodesk.com
Tue Jan 28 09:45:36 PST 2014
Before I submit this as a wishlist item, I wanted to run it past the group
to see if it's been previously discussed. I did not see any related Trac
tickets.
I have had customers request that the map selection color be changed in
cases where custom code is generating the map image with the RenderMap API.
I understand that this is configurable in the layout since it uses selection
overlays. What would it take to add this as a configurable parameter to
RenderMap or is it too deeply defined in the rendering API core?
Thank you,
Andy
View this message in context: http://osgeo-org.1560.x6.nabble.com/RenderMap-and-selection-color-wish-tp5100527.html
