[mapguide-users] mapguide-users Digest, Vol 85, Issue 25 message 6 problem solved
Jacco Wanders | TTE Consultants
wanders at engineers.nl
Thu Jan 30 02:20:20 PST 2014
Dear users,
I just the solved the problem...It was my own mistake, The coordinate system in the mapsetting was incorrect.
The bing and openstreet map service layers are working fine and fast now. There is however a displacement with the Google Map V3 layers. For the time-being bingmaps is just fine.
Below a link the fusion map:
http://tte-geosolution.mr-hosting.nl/mapguide/hembrug/Mapguide_test_bing_googlemaps.php
6. Mapguide coordinate projection issue (RD_new and commercial
maps) (Jacco Wanders | TTE Consultants)
Message: 6
Date: Wed, 29 Jan 2014 14:35:58 +0000
From: Jacco Wanders | TTE Consultants <wanders at engineers.nl>
To: "mapguide-users at lists.osgeo.org" <mapguide-users at lists.osgeo.org>
Subject: [mapguide-users] Mapguide coordinate projection issue (RD_new
and commercial maps)
Message-ID:
<41E5072787FFF54BB705A90834D189E458B82BE6 at CPI1MS01.hosting.local>
Content-Type: text/plain; charset="iso-8859-1"
Dear users,
I can't manage to make a good/accurate transformation from Dutch coordinate systeem (RD_new) to WGS84.pseudoMercator in mapguide in conjunction with commercial layers! See figure below.
[cid:image005.jpg at 01CF1D07.CE903E90]
Steps carried out:
Arcmap:
Coordinate transformation from RD_new to WGS_1984_Web_Mercator_Auxiliary_Sphere
Xy coordinate system shapfile:
WKID: 3857 Authority: EPSG
Projection: Mercator_Auxiliary_Sphere
False_Easting: 0,0
False_Northing: 0,0
Central_Meridian: 0,0
Standard_Parallel_1: 0,0
Auxiliary_Sphere_Type: 0,0
Linear Unit: Meter (1,0)
Mapguide
-Coordinate systeem override (type EPSG code: 3857)
[cid:image006.jpg at 01CF1D07.CE903E90]
I hope someone has a solution for solving this problem.
I?m using:
Windows server 2008 R2, IIS 7
Mapguide 2.5.1.7768
Maestro: 5.0.1.7889
Fusion 2.6
Thanks in advance!
Jacco Wanders
