[mapguide-users] Mapguide fusion 2.6 | geolocation issue
Hans Milling hm at geograf.dk
Thu Jan 30 04:41:41 PST 2014
You can use the Proj4js library to convert the GPS coordinates from WGS84 to
something else. Then you can see what coordinates your GPS device is
reporting relative to the projection that your map is using. This is what I
do to convert to UTM32N:
Proj4js.defs["EPSG:25832"] = "+proj=utm +zone=32 +ellps=GRS80 +units=m
+no_defs"; // Not sure if needed or this is just related to my OpenLayers
map.
var gpsll = new Proj4js.Point(gpslongitude, gpslatitude);
var source = new Proj4js.Proj('EPSG:4326');
var dest = new Proj4js.Proj('EPSG:25832');
var utm32n = Proj4js.transform(source, dest, gpsll);
console.log("x: "+umt32n.x+", y: "+utm32n.y); //<-Does not work in old
versions of IE
Best regards
  Hans Milling
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-fusion-2-6-geolocation-issue-tp5100877p5100913.html
