[mapguide-users] Fusion: customize Selection Panel
amorsell
andy.morsell at autodesk.com
Tue Jul 8 12:27:46 PDT 2014
If you are modifying the underlying widgets, you have to change your template
index.html file to reference fusion.js instead of fusionSF.js. fusionSF.js
is the single-file compiled version of fusion plus all widgets. When you
are done modifying the widgets and wanting to deploy to production, you can
recompile fusionSF.js using the methods that Jackie describes here.
http://themapguyde.blogspot.com.au/2012/10/modifying-and-patching-production.html
You may also be interested in this post.
http://adndevblog.typepad.com/infrastructure/2013/02/enable-hyperlink-in-selection-panel-of-fusion-viewer.html
View this message in context: http://osgeo-org.1560.x6.nabble.com/Fusion-customize-Selection-Panel-tp5149987p5150171.html
