[mapguide-users] Building MG with devenv
Jackie Ng
jumpinjackie at gmail.com
Thu Jul 17 05:04:59 PDT 2014
You should invoke devenv/wdexpress from the command-line after calling
setenvironment.bat/setenvironment64.bat and make sure you are building for
the CPU target that setenvironment[64].bat was initialized for.
For example, if you call setenvironment64.bat and then fire up VS, don't
build any of the solutions for x86 as the pulled in environment variables
will be configured for x64 include/linker paths and vice versa.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Building-MG-with-devenv-tp5151481p5151493.html
