[mapguide-users] Publish WFS/WMS from MapGuide OS With Maestro
Hans Milling hm at geograf.dk
Tue Jul 22 02:52:43 PDT 2014
Hi Adam
First, MapGuide does not support WFS-T, so if you want to support this in
the future you should go for GeoServer instead of MapGuide.
>From Maestro you can go to Tools - Site Administrator to configure your WFS
server.
Next you can right click at FeatureSource and select Properties to expose
it's data as WFS. The properties window have a WFS tab where you can specify
a name, bounding box, coordinate system etc.
My experience is, like James that some GIS applications does not understand
the WFS xml that MapGuide exposes. Especially if you have use none ASCII
letters in either of the properties in the Site Administrator or WFS tab or
in the column names of your data tables.
Best regards Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Publish-WFS-WMS-from-MapGuide-OS-With-Maestro-tp5152245p5152400.html
