[mapguide-users] QUERYMAPFEATURES and requestdata = 3 throws NpE
Scott Hameister scotth at mpowerinnovations.com
Mon Jun 16 20:20:34 PDT 2014
Is it buffer by a percentage or a real world unit..and if a real world unit
like meter or foot is it defined correctly?
On Jun 16, 2014 10:18 PM, "Scott Hameister" <scotth at mpowerinnovations.com>
wrote:
> Convert to real world units..it is unit less in Lat Long and psuedo..you
> can't zoom into a point which is infinite..maybe I missing something
> On Jun 16, 2014 2:12 PM, "mjirku" <martinjirku at gmail.com> wrote:
>> Thanks for the reply.
>> I probably found the problem finally now, after few hours of investigation
>> The data I am using, are here:
>> http://gis-services.sk:8009/mg/mapviewerajax/?WEBLAYOUT=Library://Bratislava/Bratislava_WGS84.WebLayout
>> And I compared it with data in original coordinating system
>> http://gis-services.sk:8009/mg/mapviewerajax/?WEBLAYOUT=Library://Bratislava/Bratislava.WebLayout
>> (you should zoom a little bit, because at this scale everything is
>> invisible, username is common mapguide username)
>> However the problem seems to be in converting coordinate systems. Original
>> data are in JTSK and the http request QUERYMAPFEATURES  outputs the bounds
>> without any problem. When data are converted in mapdefinition into WGS84
>> pseudmerc., it does not send me bounds.
>> Is this normal mapguide behavior? Do you see how I can resolve this issue?
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/QUERYMAPFEATURES-and-requestdata-3-throws-NpE-tp5145379p5146150.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140616/bb2b7ee1/attachment.html>
