[mapguide-users] QUERYMAPFEATURES and requestdata = 3 throws NpE
Scott Hameister
scotth at mpowerinnovations.com
Mon Jun 16 20:18:31 PDT 2014
Convert to real world units..it is unit less in Lat Long and psuedo..you
can't zoom into a point which is infinite..maybe I missing something
On Jun 16, 2014 2:12 PM, "mjirku" <martinjirku at gmail.com> wrote:
> Thanks for the reply.
> I probably found the problem finally now, after few hours of investigation
> The data I am using, are here:
> http://gis-services.sk:8009/mg/mapviewerajax/?WEBLAYOUT=Library://Bratislava/Bratislava_WGS84.WebLayout
> And I compared it with data in original coordinating system
> http://gis-services.sk:8009/mg/mapviewerajax/?WEBLAYOUT=Library://Bratislava/Bratislava.WebLayout
> (you should zoom a little bit, because at this scale everything is
> invisible, username is common mapguide username)
> However the problem seems to be in converting coordinate systems. Original
> data are in JTSK and the http request QUERYMAPFEATURES outputs the bounds
> without any problem. When data are converted in mapdefinition into WGS84
> pseudmerc., it does not send me bounds.
> Is this normal mapguide behavior? Do you see how I can resolve this issue?
> http://osgeo-org.1560.x6.nabble.com/QUERYMAPFEATURES-and-requestdata-3-throws-NpE-tp5145379p5146150.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140616/e39099f8/attachment.html>
