[mapguide-users] QUERYMAPFEATURES and requestdata = 3 throws NpE
mjirku
martinjirku at gmail.com
Mon Jun 16 20:49:30 PDT 2014
Hi Jackie,
Yes, It is custom client side application. It is easy to create a tiny
polygon. But selection seems to work fine with this point as well. Issue I
encounter is valid even I used tiny polygon. :(
But are there other reasons I should change my code to use tiny polygons
with QUERYMAPFEATURES?
View this message in context: http://osgeo-org.1560.x6.nabble.com/QUERYMAPFEATURES-and-requestdata-3-throws-NpE-tp5145379p5146203.html
