[mapguide-users] Postgis views not selectable when using join
Jackie Ng
jumpinjackie at gmail.com
Fri May 16 21:32:40 PDT 2014
No identity properties = un-selectable layer
FDO Providers are generally not smart enough to infer identity properties
from database views. That's why the schema override mechanism exists: To let
you specify these properties manually.
- Jacki
View this message in context: http://osgeo-org.1560.x6.nabble.com/Postgis-views-not-selectable-when-using-join-tp5139362p5140876.html
