[mapguide-users] Postgis views not selectable when using join
Scott Hameister scotth at mpowerinnovations.com
Fri May 16 21:34:44 PDT 2014
Any way to build into maestro on a layer
On May 16, 2014 11:33 PM, "Jackie Ng" <jumpinjackie at gmail.com> wrote:
> No identity properties = un-selectable layer
> FDO Providers are generally not smart enough to infer identity properties
> from database views. That's why the schema override mechanism exists: To
> let
> you specify these properties manually.
> - Jacki
> http://osgeo-org.1560.x6.nabble.com/Postgis-views-not-selectable-when-using-join-tp5139362p5140876.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140516/067966bf/attachment.html>
