[mapguide-users] tooltips in 2.6 (migration from 2.2. to 2.6)
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Thu Nov 6 10:37:26 PST 2014
Hm. Good to know - unfortunately, that doesn't seem to help. You forgot
to take off the extra bracket at the end, but despite that it doesn't
seem to help the problem. However, I have managed to find some more
clues.....
So, I turn a tooltip on another layer (nothing fancy, just an ID). This
layer is set to show all the time, no matter what scale. Here's the
interesting part - using the AJAX viewer, the tooltips for that layer
won't show up unless I'm zoomed in to some (seemingly arbitrary) scale.
So if I zoom out, I see the layer, but no tooltips. If I zoom in, I
still see the layer, but I also see tooltips. That doesn't seem to apply
to this dynamic tooltip issue - which makes me think there's more than 1
problem happening here.
To complicate the issue, in Fusion, I don't see the tooltips for that
simple layer, ever - no matter what scale. Also, I don't even see the
QUERYMAPFEATURES event firing in Fusion, which makes me think it's just
not set to show tooltips at all. The plot thickens...
On 14/11/06 11:26 AM, Berg, James wrote:
> GEMTEC Email Signature
> You don’t need to nest concat() as of mapguide 2.4. You only need to
> seperate by comma. Nesting concat won’t work. Also, your SECTIONID,
> which I’m assuming is an attribute, does not need to be in quotes. The
> correct string should look like this (not guaranteed to work because I
> can’t check it).
> concat('<iframe frameborder=0 scrolling=no marginwidth=0
> marginheight=0 height=120 width=150
> src=http://www.google.com/gis/chart.asp?Thumbnail=1&Section_ID=',
> SECTIONID, '></iframe>'))
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
GEMTEC Limited <http://www.gemtec.ca/>
*Andrew DeMerchant*
tel: 506.453.1025 / toll-free: 1.877.243.6832
fax: 506.453.9470
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141106/a81e18e5/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141106/a81e18e5/attachment.png>
