[mapguide-users] tooltips in 2.6 (migration from 2.2. to 2.6)
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Thu Nov 13 11:54:13 PST 2014
Any other thoughts on this?
On 14/11/06 2:37 PM, Andrew DeMerchant wrote:
> Hm. Good to know - unfortunately, that doesn't seem to help. You
> forgot to take off the extra bracket at the end, but despite that it
> doesn't seem to help the problem. However, I have managed to find some
> more clues.....
> So, I turn a tooltip on another layer (nothing fancy, just an ID).
> This layer is set to show all the time, no matter what scale. Here's
> the interesting part - using the AJAX viewer, the tooltips for that
> layer won't show up unless I'm zoomed in to some (seemingly arbitrary)
> scale. So if I zoom out, I see the layer, but no tooltips. If I zoom
> in, I still see the layer, but I also see tooltips. That doesn't seem
> to apply to this dynamic tooltip issue - which makes me think there's
> more than 1 problem happening here.
> To complicate the issue, in Fusion, I don't see the tooltips for that
> simple layer, ever - no matter what scale. Also, I don't even see the
> QUERYMAPFEATURES event firing in Fusion, which makes me think it's
> just not set to show tooltips at all. The plot thickens...
> On 14/11/06 11:26 AM, Berg, James wrote:
>> GEMTEC Email Signature
>> You don’t need to nest concat() as of mapguide 2.4. You only need to
>> seperate by comma. Nesting concat won’t work. Also, your SECTIONID,
>> which I’m assuming is an attribute, does not need to be in quotes.
>> The correct string should look like this (not guaranteed to work
>> because I can’t check it).
>> concat('<iframe frameborder=0 scrolling=no marginwidth=0
>> marginheight=0 height=120 width=150
>> src=http://www.google.com/gis/chart.asp?Thumbnail=1&Section_ID=',
>> SECTIONID, '></iframe>'))
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> GEMTEC Limited <http://www.gemtec.ca/>
> *Andrew DeMerchant*
> tel: 506.453.1025 / toll-free: 1.877.243.6832
> fax: 506.453.9470
*Andrew DeMerchant*
fax: 506.453.9470
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141113/8bef1ef8/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141113/8bef1ef8/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141113/8bef1ef8/attachment-0001.png>
