[mapguide-users] strange alias problem with gdal (x64)
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Wed Nov 19 13:17:33 PST 2014
I can also now confirm that the aliased composite config docs that
Maestro made using MGOS 2.2 work fine in 2.5...for me, though, making a
new composite layer using a folder alias works fine in v2.5. So at least
in my case, it seems that it's 2.6 that's broken - for me, 2.5 works
like 2.2 in this instance.
On 14/11/19 2:30 PM, Andrew DeMerchant wrote:
> Ditto here - mine were made using MGOS 2.2 (various versions of
> Maestro), composite and work fine in 2.2, but don't work in 2.6.
> Making new ones in 2.6 also don't work. Strange that you can use old
> ones in 2.5 and they work, but you can't create new ones...if you
> recreate the old working ones as new ones, what's the difference in
> the xml? To me, that almost points to a problem with Maestro (because
> you can't create new ones) and a separate problem with MGOS (because
> neither work in 2.6)...
> On 14/11/19 2:19 PM, Steve G wrote:
>> Maybe I am misinformed (definitely not the lying type), but is the patch at
>> all related to this issue:
>> http://osgeo-org.1560.x6.nabble.com/Step-by-Step-for-ECW-and-MGOS-2-4-tp4995445p4998405.html
>> Jackie, I have configuration documents for gdal providers that were created
>> way back when using MGOS2.2 and I am using aliases with the Composite type.
>> They work fine with MGOS2.5 (I have not upgraded to 2.6 yet because of the
>> gdal blocking issue). However, when creating NEW configuration documents,
>> the Single types work with aliases, but the Composite types do not. Have
>> you tested with each of these configuration types?
>> Thanks,
>> -Steve
>> View this message in context:http://osgeo-org.1560.x6.nabble.com/strange-alias-problem-with-gdal-x64-tp5173823p5173862.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> GEMTEC Email Signature
> GEMTEC Limited <http://www.gemtec.ca/>
> *Andrew DeMerchant*
> tel: 506.453.1025 / toll-free: 1.877.243.6832
> fax: 506.453.9470
*Andrew DeMerchant*
fax: 506.453.9470
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141119/192f96b0/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141119/192f96b0/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141119/192f96b0/attachment-0001.png>
