[mapguide-users] strange alias problem with gdal (x64)
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Wed Nov 19 10:30:51 PST 2014
Ditto here - mine were made using MGOS 2.2 (various versions of
Maestro), composite and work fine in 2.2, but don't work in 2.6. Making
new ones in 2.6 also don't work. Strange that you can use old ones in
2.5 and they work, but you can't create new ones...if you recreate the
old working ones as new ones, what's the difference in the xml? To me,
that almost points to a problem with Maestro (because you can't create
new ones) and a separate problem with MGOS (because neither work in 2.6)...
On 14/11/19 2:19 PM, Steve G wrote:
> Maybe I am misinformed (definitely not the lying type), but is the patch at
> all related to this issue:
> http://osgeo-org.1560.x6.nabble.com/Step-by-Step-for-ECW-and-MGOS-2-4-tp4995445p4998405.html
> Jackie, I have configuration documents for gdal providers that were created
> way back when using MGOS2.2 and I am using aliases with the Composite type.
> They work fine with MGOS2.5 (I have not upgraded to 2.6 yet because of the
> gdal blocking issue). However, when creating NEW configuration documents,
> the Single types work with aliases, but the Composite types do not. Have
> you tested with each of these configuration types?
> Thanks,
> -Steve
> View this message in context: http://osgeo-org.1560.x6.nabble.com/strange-alias-problem-with-gdal-x64-tp5173823p5173862.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
GEMTEC Email Signature
GEMTEC Limited <http://www.gemtec.ca/>
*Andrew DeMerchant*
tel: 506.453.1025 / toll-free: 1.877.243.6832
fax: 506.453.9470
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141119/dc756466/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141119/dc756466/attachment.png>
