[mapguide-users] MapGuide Open Source 3.0 test build for 64-bit Linux
scoobylx
brandon.mason at maritimearchaeology.co.uk
Thu Oct 16 02:40:46 PDT 2014
Sorry, GDAL was just an error in the path. All working fine.
Postgres/postgis provider not so happy. I have the following in
/usr/local/fdo-3.9.0/lib:
libFdoPostgreSQL-3.9.0.so
libFdoPostgreSQL.so
It's libpq.so.5 not found.
System.Exception: The remote server returned an error: (559)
MgFdoException.:
An exception occurred in FDO component.
Unable to load the FDO Provider library 'libFdoPostgreSQL.so': libpq.so.5:
cannot open shared object file: No such file or directory (Cause: , Root
Cause: Unable to load the FDO Provider library 'libFdoPostgreSQL.so':
libpq.so.5: cannot open shared object file: No such file or directory)
- MgFeatureServiceHandler.ProcessOperation() line 83 file
FeatureServiceHandler.cpp
- MgOpGetCapabilities.Execute() line 124 file OpGetCapabilities.cpp
---> System.Net.WebException: The remote server returned an error: (559)
MgFdoException.
at System.Net.HttpWebRequest.GetResponse()
at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OpenRead(String req) in
c:\working\JenkinsCI\home\slave_win\jobs\Maestro
trunk\workspace\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line
1417
--- End of inner exception stack trace ---
1433
at
OSGeo.MapGuide.MaestroAPI.HttpServerConnection.GetProviderCapabilities(String
provider) in c:\working\JenkinsCI\home\slave_win\jobs\Maestro
1858
at Maestro.Base.Editor.FsEditorOptionPanel.Bind(IEditorService service)
trunk\workspace\Maestro.Base\Editor\FsEditorOptionPanel.cs:line 62
at Maestro.Base.Editor.FeatureSourceEditor.Bind(IEditorService service)
trunk\workspace\Maestro.Base\Editor\FeatureSourceEditor.cs:line 71
at Maestro.Base.Editor.EditorContentBase.set_EditorService(IEditorService
value) in c:\working\JenkinsCI\home\slave_win\jobs\Maestro
trunk\workspace\Maestro.Base\Editor\EditorContentBase.cs:line 117
at Maestro.Base.Services.OpenResourceManager.Open(IResource res,
IServerConnection conn, Boolean useXmlEditor, ISiteExplorer siteExp) in
trunk\workspace\Maestro.Base\Services\OpenResourceManager.cs:line 192
at Maestro.Base.Services.OpenResourceManager.Open(String resourceId,
trunk\workspace\Maestro.Base\Services\OpenResourceManager.cs:line 265
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-Open-Source-3-0-test-build-for-64-bit-Linux-tp5167443p5167789.html
