[mapguide-users] MapGuide Open Source 3.0 test build for 64-bit Linux
Michele Mondelli
mithenks.ml at gmail.com
Thu Oct 16 03:32:29 PDT 2014
Hi sboobylx,
I think you need the PostgreSQL development header files and libraries.
Run
$ yum provides */libpq
to find what package provide them for you.
On our system, we have
installed postgresql93-devel-9.3.5-1PGDG.rhel6.x86_64 for it.
Regards,
2014-10-16 11:40 GMT+02:00 scoobylx <brandon.mason at maritimearchaeology.co.uk
> Sorry, GDAL was just an error in the path. All working fine.
> Postgres/postgis provider not so happy. I have the following in
> /usr/local/fdo-3.9.0/lib:
> libFdoPostgreSQL-3.9.0.so
> libFdoPostgreSQL.so
> It's libpq.so.5 not found.
> System.Exception: The remote server returned an error: (559)
> MgFdoException.:
> An exception occurred in FDO component.
> Unable to load the FDO Provider library 'libFdoPostgreSQL.so': libpq.so.5:
> cannot open shared object file: No such file or directory (Cause: , Root
> Cause: Unable to load the FDO Provider library 'libFdoPostgreSQL.so':
> libpq.so.5: cannot open shared object file: No such file or directory)
> - MgFeatureServiceHandler.ProcessOperation() line 83 file
> FeatureServiceHandler.cpp
> - MgOpGetCapabilities.Execute() line 124 file OpGetCapabilities.cpp
> ---> System.Net.WebException: The remote server returned an error: (559)
> MgFdoException.
> at System.Net.HttpWebRequest.GetResponse()
> at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OpenRead(String req)
> in
> c:\working\JenkinsCI\home\slave_win\jobs\Maestro
> trunk\workspace\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line
> 1417
> --- End of inner exception stack trace ---
> in
> 1433
> at
> OSGeo.MapGuide.MaestroAPI.HttpServerConnection.GetProviderCapabilities(String
> provider) in c:\working\JenkinsCI\home\slave_win\jobs\Maestro
> 1858
> at Maestro.Base.Editor.FsEditorOptionPanel.Bind(IEditorService service)
> trunk\workspace\Maestro.Base\Editor\FsEditorOptionPanel.cs:line 62
> at Maestro.Base.Editor.FeatureSourceEditor.Bind(IEditorService service)
> trunk\workspace\Maestro.Base\Editor\FeatureSourceEditor.cs:line 71
> at
> Maestro.Base.Editor.EditorContentBase.set_EditorService(IEditorService
> value) in c:\working\JenkinsCI\home\slave_win\jobs\Maestro
> trunk\workspace\Maestro.Base\Editor\EditorContentBase.cs:line 117
> at Maestro.Base.Services.OpenResourceManager.Open(IResource res,
> IServerConnection conn, Boolean useXmlEditor, ISiteExplorer siteExp) in
> trunk\workspace\Maestro.Base\Services\OpenResourceManager.cs:line 192
> at Maestro.Base.Services.OpenResourceManager.Open(String resourceId,
> trunk\workspace\Maestro.Base\Services\OpenResourceManager.cs:line 265
> http://osgeo-org.1560.x6.nabble.com/MapGuide-Open-Source-3-0-test-build-for-64-bit-Linux-tp5167443p5167789.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
*Michele Mondelli*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20141016/4f284ca2/attachment.html>
