[mapguide-users] MapGuide Open Source 3.0 test build for 64-bit Linux
Jackie Ng
jumpinjackie at gmail.com
Thu Oct 16 17:42:06 PDT 2014
If you are using the docker approach (as per my blog post), it pre-dates this
64-bit Linux build.
So you're basically installing a 32-bit application (MapGuide) in a 64-bit
container and host. Whatever dependencies you have to install must be the
*32-bit* version and not the 64-bit one.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-Open-Source-3-0-test-build-for-64-bit-Linux-tp5167443p5167916.html
