[mapguide-users] Leaflet & MapGuide
    amorsell
    andy.morsell at autodesk.com
    Mon Sep  8 09:02:33 PDT 2014
I was doing a little research on this and am able to confirm that this does
not work with AIMS 2015.  I published all layers (plus trees for points) in
the standard Sheboygan sample map, made sure that they were set to queryable
when publishing, then used Gaia to try to retrieve their info.  It worked
fine for Parcels, but returns a null <FeatureInfoCollection> for Roads and
Trees.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Leaflet-MapGuide-tp5083729p5160730.html
