[mapguide-users] Step by Step Mrsid Gdal support implementation for packaged MGOS 2.5.1
Andrew DeMerchant andrew.demerchant at gemtec.ca
Mon Sep 8 12:28:33 PDT 2014
Thanks very much for this! I wish they'd just include these in every
version - it's a pain to always have to hunt for the dlls for every MGOS
release...one of the many reasons I'm still running an old version
(2.2), sadly.
So I take it that 2.6 can't do mr sids at all, since it seems to be
compiled using MSV2012?
On 14/09/05 3:23 PM, Berg, James wrote:
> I've had to install Mr SID on MapGuide Open Source  2.5.2 64-bit
> recently and documented what I did. Here are the directions I wrote:
> Mr SID is a raster image format that is not supported by MapGuide Open
> Source by default. You must install support manually by adding .dll
> files to specific folders in the MapGuide installation. The .dll files
> (binaries) can be found on this website:
> http://www.gisinternals.com/sdk/. A set of binaries downloaded from
> this site contains all of the binaries needed to add support for all
> sorts of extra raster formats, not just Mr SID.
> However, gisinternals lists many, many sets of binaries and only one
> set will work with your installation of MapGuide Open Source. There
> are three criteria to determine which set you should download:
> 1.Which version of C++ your MapGuide Open Source was compiled in.
> There are three versions
> a.MSVC2005
> b.MSVC2008
> c.MSVC2010
> d.MSVC2012 (not released yet as of 9/5/2014)
> 2.The "bitness" of your MapGuide Open Source. "Bitness" refers to
> either 32-bit or 64-bit.
> 3.What version of GDAL your MapGuide Open Source is using.
> Okay, but how do you figure out your MapGuide's C++ version, bitness,
> and GDAL version? The MapGuide OS 2.5.2 64-bit has the following
> characteristics:
> 1.C++: MSVC2010
> 2.Bitness: 64-bit
> 3.GDAL version: 1.9.0
> Now that we know what to download, let's visit gisinternals and select
> a set of binaries. Here's how to find it:
> This is the set of binaries we need. Click the
> release-1600-x64-gdal-1.9.0-mapserver-6-0-1 hyperlink.
> A new window will appear. Click the first link with the description,
> "Compiled binaries in a single .zip package."
> Extract the zip file. The folder structure will look something like this:
> Inside the bin folder is something like this.
> Inside the bin/gdal/plugins folder is something like:
> The binaries in the bin and bin/gdal/plugins folder are what we're
> interested in. The binaries the bin/gdal/plugins folder contains the
> master .dll files needed to install support for a new raster format.
> These master binaries depend on the binaries in the /bin folder. Where
> do I put the binaries from bin and bin/gdal/plugins folders? That
> depends on what raster format you're trying to install.
> __
> _Mr SID_
> First, create a folder under C:\Program
> Files\OSGeo\MapGuide\Server\bin called gdalplugins.
> There are three directories we'll be copying .dll files to under
> C:\Program Files\OSGeo\MapGuide\Server\:
> ·bin/gdalplugins
> ·bin
> ·fdo
> Copy .ddl files from the bin/gdal/plugins and bin folders from the set
> of binaries to the following directories:
> Server\bin\gdalplugins\gdal_MrSID.dll
> Server\bin\libecwj2.dll
> Server\bin\lti_dsdk_dll
> Server\Fdo\gdal19.dll
> Server\Fdo\geos_c.dll
> Server\Fdo\iconv.dll
> Server\Fdo\libcurl.dll
> Server\Fdo\libexpat.dll
> Server\Fdo\libpq.dll
> Server\Fdo\libtiff.dll
> Server\Fdo\proj.dll
> Server\Fdo\spatialite.dll
> Server\Fdo\xerces-c_2_8.dll
> Server\Fdo\zlib1.dll
> Server\Fdo\ssleay32.dll
> Server\Fdo\libeay32.dll
> Server\Fdo\libmysql.dll
> Server\Fdo\openjpeg.dll
> Restart your MapGuide service, and you'll be able to create feature
> sources from Mr SID rasters. If you've been trying to create feature
> sources already, you may have to re-create your feature source from
> scratch for it to work.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
GEMTEC Email Signature
GEMTEC Limited <http://www.gemtec.ca/>
*Andrew DeMerchant*
tel: 506.453.1025  /  toll-free: 1.877.243.6832
fax: 506.453.9470
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140908/4613a067/attachment.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140908/4613a067/attachment.jpe>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140908/4613a067/attachment-0001.jpe>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140908/4613a067/attachment-0002.jpe>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140908/4613a067/attachment-0003.jpe>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140908/4613a067/attachment-0004.jpe>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140908/4613a067/attachment.png>
