[mapguide-users] Loading tif using GDAL
Farhan Khan
mrfarhankhan at gmail.com
Mon Sep 29 11:30:23 PDT 2014
I am really grateful for your help.
In the GDAL Feature Source window, I'm using the following
1. Type - Single
2. File System
I am using the Local Preview button at the bottom. As per your suggestion,
I will now try to use the Preview button on the toolbar and report back on
how it went.
Thanks
Farhan!
On Mon, Sep 29, 2014 at 11:22 PM, Steve G <stevenlgolden at gmail.com> wrote:
> In the GDAL Feature Source window, what method are you using to connect to
> the data?
> 1. Type - Single or Composite
> 2. File System or Alias
> Also, are you using the Local Preview button at the bottom or the Preview
> button on the toolbar? You should use the Preview button on the toolbar.
> It will load the schema view in a new browser window. You should be able
> to
> see a link "View Data" and once you click on that, the right frame will be
> populated with all the tif files being exposed. If it says "total
> entries:-1" then something failed. Also remember to
> In the not so recent past, I have had issues with the Composite type
> method:
> http://osgeo-org.1560.x6.nabble.com/Step-by-Step-for-ECW-and-MGOS-2-4-tp4995445p4998405.html
> If this is the method that you have been using and it fails, try using the
> Single type method (choose the folder where all the tif files are). And I
> would also start from the beginning (open a new resource and select single
> method). For some reason I've noticed that if you try to change from
> composite to single type method, you can't...it seems like you can't purge
> the configuration even after a save.
> Steve
> http://osgeo-org.1560.x6.nabble.com/Loading-tif-using-GDAL-tp5164516p5164792.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140929/adc45c4b/attachment.html>
