[mapguide-users] Loading tif using GDAL
Farhan Khan
mrfarhankhan at gmail.com
Mon Sep 29 21:41:57 PDT 2014
ok, i tried it. the same exception pops up again
"unknown entity reference".
how can i resolve this ?
On Mon, Sep 29, 2014 at 11:30 PM, Farhan Khan <mrfarhankhan at gmail.com>
wrote:
> I am really grateful for your help.
> In the GDAL Feature Source window, I'm using the following
> 1. Type - Single
> 2. File System
> I am using the Local Preview button at the bottom. As per your suggestion,
> I will now try to use the Preview button on the toolbar and report back on
> how it went.
> Thanks
> Farhan!
> On Mon, Sep 29, 2014 at 11:22 PM, Steve G <stevenlgolden at gmail.com> wrote:
>> In the GDAL Feature Source window, what method are you using to connect to
>> the data?
>> 1. Type - Single or Composite
>> 2. File System or Alias
>> Also, are you using the Local Preview button at the bottom or the Preview
>> button on the toolbar? You should use the Preview button on the toolbar.
>> It will load the schema view in a new browser window. You should be able
>> to
>> see a link "View Data" and once you click on that, the right frame will be
>> populated with all the tif files being exposed. If it says "total
>> entries:-1" then something failed. Also remember to
>> In the not so recent past, I have had issues with the Composite type
>> method:
>> http://osgeo-org.1560.x6.nabble.com/Step-by-Step-for-ECW-and-MGOS-2-4-tp4995445p4998405.html
>> If this is the method that you have been using and it fails, try using the
>> Single type method (choose the folder where all the tif files are). And I
>> would also start from the beginning (open a new resource and select single
>> method). For some reason I've noticed that if you try to change from
>> composite to single type method, you can't...it seems like you can't purge
>> the configuration even after a save.
>> Steve
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Loading-tif-using-GDAL-tp5164516p5164792.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140930/a58c89d3/attachment.html>
