[mapguide-users] Mapguide and ODBC
Gord McKenzie
gord.mckenzie at canam.com
Thu Apr 23 13:36:21 PDT 2015
No. When I use the Preview option on the extended class of my Feature Source then I only see the extended attributes from the SQL Server table on about 15% of the records. The rest of the records show the FeatureID and the key column from the sdf file but the corresponding SQL Server data is blank.
When I make a corresponding link in AutoCAD Map 2012, using the same sdf file and SQL Server table, I get 100% of the records matching correctly.
Gordon McKenzie
GIS Coordinator
T: 403.269.8887 / 1.800.478.6162
E: Gord.Mckenzie at canam.com canam.com
900, 340 - 12th Avenue SW Calgary, AB T2R 1L5
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Thursday, April 23, 2015 7:05 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Mapguide and ODBC
Just to confirm: You can view the data of the extended feature class just fine with all the right-side attributes being there, but when you render a layer off of it you are getting different results?
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-and-ODBC-tp5202365p5202655.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
