[mapguide-users] Mapguide and ODBC
Jackie Ng jumpinjackie at gmail.com
Sun Apr 26 19:56:09 PDT 2015
I'm afraid at this point, we'll need a small reproducible sample of this
problematic SDF/SQL Server join in order to look at this issue any further.
Something that is 50-100 rows on either side with the sensitive information
(except for the joining keys) sanitized/replaced should be sufficient.
IIRC MapGuide and AutoCAD Map share the same Feature Join engine. I'd be
interested to know if this SDF <-> SQL Server join looks the same in AutoCAD
Map 2013 or newer should you have access to such a version.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-and-ODBC-tp5202365p5203003.html
