[mapguide-users] Mapguide and ODBC
Gord McKenzie
gord.mckenzie at canam.com
Mon Apr 27 12:43:57 PDT 2015
I will work to get you a sample. Not sure what my best method is for selecting a subset of records as I have not identified a good pattern in the data but I will work to get a subset that has some that match and some that don't.
AutoCAD Map 2012, 2013 and 2015 all work as expected.
I have tried Mapguide 2.2 32 bit, Mapguide 2.5 64 bit and Mapguide 2.6 32 bit. All fail to join the data correctly.
Thanks
Gordon McKenzie
GIS Coordinator
T: 403.269.8887 / 1.800.478.6162
E: Gord.Mckenzie at canam.com canam.com
900, 340 - 12th Avenue SW Calgary, AB T2R 1L5
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Sunday, April 26, 2015 8:56 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Mapguide and ODBC
I'm afraid at this point, we'll need a small reproducible sample of this problematic SDF/SQL Server join in order to look at this issue any further.
Something that is 50-100 rows on either side with the sensitive information (except for the joining keys) sanitized/replaced should be sufficient.
IIRC MapGuide and AutoCAD Map share the same Feature Join engine. I'd be interested to know if this SDF <-> SQL Server join looks the same in AutoCAD Map 2013 or newer should you have access to such a version.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-and-ODBC-tp5202365p5203003.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
