[mapguide-users] Using an external WMS in MapGuide Maestro
Hans Milling
hm at geograf.dk
Fri Dec 4 00:41:04 PST 2015
The minx > maxx error is a common error when Maestro creates a preview
runtime map. If you setup a map yourself and add the WMS layer, you can
preview this map with no errors.
Please pay attention to what Coordinate system you use for the map, remember
on the WMS feature source to set the same coordinate system for the layers.
Also be sure to remove "Selectable" (Set it to false) for any raster/WMS
layers as this makes no sense and can often cause MapGuide to throw some
errors.
Best regards
Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Using-an-external-WMS-in-MapGuide-Maestro-tp5235696p5239980.html
