[mapguide-users] Error using quickplot - TCPDF ERROR: [Image] Unable to get image:
JamesDudden jamesdudden at blueyonder.co.uk
Fri Feb 6 02:52:12 PST 2015
I have run in to a problem that only happens when I turn on too many layers
i.e. there is always a tipping point where it works then I switch on more
layers and then it stops working.  I am using MG Open Source 2.5 on Windows
Server 2008 with a .NET build.  The map has many linked layers including
SHP, TIFF and MS Access.
The error is as follows:
http://localhost/mapguide/fusion/widgets/QuickPlot/GeneratePicture.php?session_id=4d63d044-adec-11e4-8000-001e6779bb86_en_MTI3LjAuMC4x0AFC0AFB0AFA&map_name=SolarMap_Print54d499ac870fe&print_size=1163.6,802.9&print_dpi=96&box=-320022.97641722555,6718419.613604725,-174572.97641722555,6718419.613604725,-174572.97641722555,6818782.113604725,-320022.97641722555,6818782.113604725&normalized_box=-320022.97641722555,6718419.613604725,-174572.97641722555,6718419.613604725,-174572.97641722555,6818782.113604725,-320022.97641722555,6818782.113604725&scale_denominator=125000&rotation=0
I found this old thread
(http://osgeo-org.1560.x6.nabble.com/TCPDF-ERROR-Image-Unable-to-get-image-td5098056.html)
that has the same issue and as per the thread copying the url from the error
into the address bar works but unfortunately this is not a great solution
for my client who needs the  title/sub title you get with the proper
quickplot route plus the option to save as a PDF.
Any help is greatly appreciated
RegardsJD
Software-Matters
Dorset
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-using-quickplot-TCPDF-ERROR-Image-Unable-to-get-image-tp5185933.html
