[mapguide-users] Error using quickplot - TCPDF ERROR: [Image] Unable to get image:
Jackie Ng
jumpinjackie at gmail.com
Fri Feb 6 03:12:11 PST 2015
If you get that error, it would be generally be because GeneratePicture.php
threw some sort of error causing an exception message to be returned instead
of an image. TCPDF tries to process that exception message as an image and
throws the aforementioned error as a result.
You should see what the GeneratePicture.php url is being generated by
PlotAsPDF.php and load that raw URL to see what kind of error
GeneratePicture.php is throwing back.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-using-quickplot-TCPDF-ERROR-Image-Unable-to-get-image-tp5185933p5185937.html
