[mapguide-users] mapguide rest - bbox parameter with map?
Fritz Robert Robert.Fritz at win.ch
Wed Feb 18 04:51:04 PST 2015
Hi Jackie,
yes, I think I misunderstood the concept. Things are much clearer now,
Thank you for your replies,
Rob
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Jackie Ng
Gesendet: Mittwoch, 18. Februar 2015 04:05
An: mapguide-users at lists.osgeo.org
Betreff: Re: [mapguide-users] mapguide rest - bbox parameter with map?
I think you might be misunderstanding the purpose of the image representation in restcfg.json
Features will *always* be selected in the image representation. This is by design. The intention behind the image representation is to show where your
feature(s) are in relation to the map specified in restcfg.json, and we do that by showing such features as selected on the map. GeoREST follows this same idea. Your feature(s) are the centre of attention, not the map.
If you are just after an image of a map at a certain view, then you can just use the image representation of the map definition:
eg.
http://localhost/mapguide/rest/library/Testing/report/AV_Vorlage.MapDefinition/image.png?x=YOUR_CENTER_X&y=YOUR_CENTER_Y&scale=YOUR_SCALE&width=YOUR_IMAGE_WIDTH&height=YOUR_IMAGE_HEIGHT
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/mapguide-rest-bbox-parameter-with-map-tp5187340p5188279.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
