[mapguide-users] Cannot edit WMS configuration document in Maestro
Gunter Becker gunter.becker at csogis.de
Thu Feb 26 03:01:53 PST 2015
Hi all,
i have quite some problems with the consumption of nearly all WMS services
like for example:
http://services.lgrb-bw.de/index.phtml?SERVICE_NAME=lgrb_uek350_boden or
https://geoportal.frankfurt.de/opendata/odlb12fbgqgk.exe
Without overriding any of the default parameters ("Advanced") everything
works like expected. But when editing the configuration document via the
editor, the next connection to the WMS server fails. Hitting the "Test
Connection"-Button results in an unclassified error. Error.log:
The WMS services are all accessible without any credentials but it seems
they are required!?
I have tested this behaviour with MG 2.4, MG 2.6, MG 3.0 by using Maestro
5.1, Maestro 6.0, Mastro from trunk and Infrastructure MapServer 2015
As a side note: when trying to edit the configuration document as XML I
can't save it back to the FeatureSource. It fails with the message: There is
no unicode byte order mark:cannot switch to unicode.
Someone else must have this problems to or maybe I am doing something
completely wrong.
Any ideas?
Gunter
View this message in context: http://osgeo-org.1560.x6.nabble.com/Cannot-edit-WMS-configuration-document-in-Maestro-tp5190218.html
