[mapguide-users] Cannot edit WMS configuration document in Maestro
Jackie Ng
jumpinjackie at gmail.com
Thu Feb 26 03:14:50 PST 2015
When you get that byte order mark warning, do you see encoding="utf-16" in
the XML prolog of that configuration document? Does manually changing that
to encoding="utf-8" remove the warning?
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Cannot-edit-WMS-configuration-document-in-Maestro-tp5190218p5190222.html
